454 big block - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-06-2012, 09:02 AM
454 big block
hey i took a 454 out of a 85 suburban, and changed the heads to ones out off of a chevelle. went from peanut to oval ports! but it seems like i a missing on the initial get down. could this be due to the heads being taller from the chevelle then the original ones? if so do i need to change the rods or can i just to to a cam that is bigger to get full contact on the rods to open the valves all the way on the stroke?
Old 02-06-2012, 09:11 AM
stich626's Avatar
gearheadslife
Last journal entry: The TwoTonShu #10
what... heads taller?
Old 02-06-2012, 10:49 AM
Yes i think they are?
Old 02-06-2012, 10:58 AM
stich626's Avatar
gearheadslife
I have 454 peanuts
454 rec port, and dart pro1's
the ports are bigger on all but the peanut, but the heads themselves are not taller..
Old 02-06-2012, 11:12 AM
NOlowrider's Avatar
US Navy-Retired
That era of the BBC are low compression slugs. You need to ditch the coffee can pistons to get the CR up and swap out for a better cam and intake. They can be made into a great engine, but it will take some work. Getting rid of the peanut port heads is a great start, but it's not enough. JMO
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Any chance you have a BBC tall deck block? I've heard some BBC truck blocks might be, maybe only commercial vehicles, not sure, not a BB person. Does the intake sit squarely and flat on the heads with no gaps?
BTW, a "bigger" cam isn't going to fix it.
Semper Fi
Old 02-06-2012, 11:31 AM
stich626's Avatar
gearheadslife
you're thinking 366/427(truck)/502
Old 02-06-2012, 11:37 AM
So what so u think can be causing the lack on the initial take off?
And any suggestions on a good cam to slap in there? The heads havw already been done!
Old 02-06-2012, 09:30 PM
bigblockragtop's Avatar
Did you accurately set up the timing?
Long block short block fitted block what do opelitis5 Hotrodding Basics 4 01-10-2010 06:12 PM
Need advise for trade. 408 short block for dart iron eagle block sherman8r Engine 6 12-06-2009 04:37 PM
BLOCK Sanding dyna block or LONGBOARD?? D9ZZ Body - Exterior 6 06-26-2008 08:10 AM
small block big block weight difference Jmark Engine 3 02-04-2008 12:21 PM
