454 big block camshaft change - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-03-2010, 01:04 AM
OK so i have 454 in my truck and i want to change the cam to a mild rv cam. but the truth is i just don't know enough about cams to know what to get. i want one that will give the engine good low end power but at the same time good throttle response and a smooth idle not a lumpy barely running idle. so if any one has any suggestions id appreciate it thanks for reading
Old 08-03-2010, 02:35 AM
techinspector1's Avatar
Wiki Edits: 326
Someone among us will have answers for you, but an intelligent reply will require further information. Detail the vehicle and its use please.
Old 08-03-2010, 05:49 PM
more info on my engine
my 454 is in a gmc sierra grande 3/4 ton camper special 2 wheel drive truck i currently only use it as a daily driver and to haul stuff . i would also like it to tow with no problem. which im sure it wouldn't have any problem doing so as it sits but i just would like a mild cam as i explianed just not sure what to go with.
454 big block turbo bizerk Engine 6 05-13-2009 10:08 PM
Small Block Vs. Big Block rhanshaw Engine 30 12-26-2007 03:02 PM
Installing Roller Camshaft in Mark IV Big Block - What Mods are Required? leejoy Engine 23 12-18-2007 04:51 PM
Big block 454 and small block match up boneyard Buick Engine 9 01-27-2006 08:27 PM
small block vs big block JUSTINH Engine 28 02-17-2003 05:37 PM
