Build hot rod how-to articles
100+ user-created articles:
'37-'57 Buick Olds Pontiac suspension upgrade, Body-exterior tips, Bulletproof cooling system, Buying a trailer, Cheapo paint job, Cold air intakes, Cylinder head choice, Determining TDC, E85, Epoxy primer, First paint job, Free T-Bucket plans, GM transmissions, Head gasket, Header design, Health and safety, How to find an electrical drain, How to title a hot rod, How to identify a Ford V8, Make a fiberglass fan shroud, Media blasting, Patching a body panel, Pitted rust, Pre-1980 VIN decoding, Removing stuck fasteners, Rewiring a vehicle, Waterproof panelboard, Why not to use a SBC engine, and many more...
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 03-31-2008, 02:36 PM
1967chevelle454's Avatar
1967chevelle454 1967chevelle454 is offline
454 block machining
I'm getting ready to send my 454 block to get all the machine work done. My questions are what all should be done to the block to get it ready for engine assembly besides the overbore I need? It's a bare block 4-bolt main stock bore.
Old 03-31-2008, 05:32 PM
Guy Hiltz's Avatar
Guy Hiltz Guy Hiltz is offline
454 block machining
Deck the block
Align hone mains
Press on new pistons ?
Resize rods/new rod bolts
Plate hone after boring
Polish/turn crank journals
Balance crank/rods/pistons
HTH
Guy
Old 03-31-2008, 06:33 PM
68NovaSS's Avatar
68NovaSS 68NovaSS is offline
Moderator
 68NovaSS's barnstar
Wiki Edits: 3
re: 454 block machining
If you're just doing the machine work now, send the pistons with.
The most flammable type of wood is a chip on the shoulder
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "454 block machining"
machining a big block 366T eljblazer Engine 4 09-27-2006 12:02 PM
454 Big Block vankissm Engine 14 08-30-2005 08:14 PM
wanting to twin turbo a 454 big block cherry_camaro Engine 12 07-31-2005 07:47 PM
Chevy Big Block 454 Marine heads 71 nova Engine 4 09-03-2004 05:08 PM
402 block with 454 crank what type piston stoneyone2001 Engine 3 10-06-2003 05:43 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
