454 blower questions - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 02-01-2013, 02:57 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Got it, flat tappet or roller?
On the nitrous issue, it makes a ton of power but can be brutal on parts, and not as fun as full time boost on tap, if you go nitrous, use it with caution. Problem is E85 isn't available everywhere, although cheaper than gas, it takes a lot more of it to get to the high power levels, similar to alcohol.
Semper Fi
The Following User Says Thank You to 68NovaSS For This Useful Post:
Mr big block! (02-01-2013)
  #32 (permalink)
Old 02-01-2013, 03:11 PM
Flat tappet. I was going through some paper work and trying to find more specs but i have so damn much. How ever i did figure out after looking through some invoices at part numbers and such, Being that i have 0.240 thousand dome forged 38 cc pistons, and 118 cc semi open combustion chamber heads, i am actually closer to 10.8-1 compression ratio. I really want to make this blower work! But nitrous would probably be easier.
  #33 (permalink)
Old 02-01-2013, 03:24 PM
vinniekq2's Avatar
how much more horse power do you want? If you can post all the specs,maybe we can find the easiest way to get whaT you want? try and fine the head flow numbers and cam part number,68nova can work with that.I will throw in my 2 cents worth best I can
The Following User Says Thank You to vinniekq2 For This Useful Post:
  #34 (permalink)
Old 02-01-2013, 04:27 PM
look on the summit websit my heads are the edebrock 60555 part number. The cam part # is cca-k11-213-3
Look on the summit racing site and you can see the exact parts. It is a slightly different cam than i thought, but easy to mix everything up when i am building so much crap. lol.
  #35 (permalink)
Old 02-01-2013, 05:29 PM
vinniekq2's Avatar
heads look good,like support over 600 hp N.A.
The cam ,if changed to a roller would likely add a fair amount of power,same with a Victor intake.
The personality of the engine would be different,moving the power band up in the range
  #36 (permalink)
Old 02-01-2013, 05:35 PM
Thanks Vinnie, What do you think would make a better more radical cam? something by voodoo, or Thumpr cams . Any thoughts on a certain one. And as i mentioned earlier i do have that Offenhouser intake little taller and single plane, for higher rpm's. Any ideas?
  #37 (permalink)
Old 02-01-2013, 05:50 PM
vinniekq2's Avatar
sell the offy and peformer and get a vic
a cam like this solid roller
120173-12 NA 273 279 241 247 .646 .646 112 108 .022 .022 1,2,5
2800-6900 Fair idle, Street/Strip, strong mid range torque. 10.0:1 CR, 2800+ stall.
about the same advertised duration at 050,but nothing like your cam at all.Your cam probably starts to roll over at 5200.this Cam would pull another 1200 rpm and it would already be making more power than what you have when your cam is finished.
If you decide you really need to have a boosted engine:
Maybe use two baby GT45 turbos and make 900 hp with 12 pounds boost
  #38 (permalink)
Old 02-01-2013, 06:06 PM
That Cam actually looks and sounds pretty nice for this application. So you think go with the solid huh? Hmm,, They are better performing but a little more maint. Victor JR on the intake. K i'll look into them too and see what my options are on them. Thanks Vinnie.
  #39 (permalink)
Old 02-01-2013, 06:17 PM
vinniekq2's Avatar
fyi.I use a bigger cam in my small block and a bigger carb,you have lots of room to grow.The solid roller is no comparison to a hydraulic anything
  #40 (permalink)
Old 02-01-2013, 09:33 PM
ok taking all into consideration from all advice. Going much larger with cam, and sollid cam and lifters, what is your thought in me using a tunnel rum, duel quad, for this upgrade? is it a wise decision, or should i keep it single carb? if i don't use the blower then i will want to maximise my potential as much as possible. Advice? I do fancy the duel quad look as well.i want to increase my mid and top end torque as much as possible, and should i use 500 cfm's if going duel, or 600's? and will this create a dead spot in instant acceleration, i also want to avoid that? Thank you all so much
  #41 (permalink)
Old 02-01-2013, 10:00 PM
vinniekq2's Avatar
That cam I mentioned is still quite small,,,
If you go dual quads,I think 2X750 as a minimum.
we have a few guys here that use street tunnel rams,they will jump in fast. I used 2X750 on a street 350.
sounds like you are making a big change in tune as apposed to a moderate upgrade
  #42 (permalink)
Old 02-01-2013, 10:12 PM
Yes definately a big change in tune and a big upgrade. i fugure if i am going to change i am going to make it a good one and be happy with it, so i don't have to keep dumping $$$$$$ in it every week because it's not at my level of expectation. I want it to launch hard out of the hole and still set you in the seat at 70 mph. with no hesitation or complications. so i think i will try the duel tunnel with duel 750's. what would you recommend for model on the carbs and intake? edelbrock, holly, ?? and what cam enters your mind for radical acceleration and full performance. I have a brand new 2,400 hughes stall for my th400 already.
  #43 (permalink)
Old 02-01-2013, 10:16 PM
I also have abrand new b&m th350 built to the hilt i could throw in it that would give me a little more snap. But don't think it would hold up very long against the big blocks abusive attitude, lol
  #44 (permalink)
Old 02-01-2013, 10:30 PM
vinniekq2's Avatar
121163-08 NA 291 299 259 267 .663 .680 108 104 .022 .022 1,2,5
3400-7200 Lopey idle, Bracket E.T. Good mid range torque. Needs 11.5:1+ CR.
converter would be 4500.
You are probably maxed out with your heads now.
All the parts need to match.
I think the preceding step mentioned would be a lot more street friendly.
Now even I would consider boosting. Then you can aim for 800-1000 HP,buts thats a whole new engine,,,,lets see if nova SS gets in here soon
Mr big block! (02-02-2013)
  #45 (permalink)
Old 02-02-2013, 12:41 PM
bigblockragtop's Avatar
I went that route and started with approximately 600 hp. I changed to a procharged 496 with 800(total guess)hp. The difference is huge. The car is now very violent to drive. It went from fast to scary fast. I am not so sure this was really needed but it is done now. I have a 6 speed manual 90-10front shocks no sway bar good weight transfer slide a link and drag radials with 3.9 gears. First gear is useless 2cnd not much better I do not get to hook and go until 3rd and even that causes tire spin. I must say I picked up that mid range like you want but by the time I could get it to hook the rice rocket would be gone. Also the lower compression gave up some thump out of the exhaust. Sounds crazy but the 600hp sounded better idling and cruising.W.O.T is a different story though. I think a shot of nitrous would not be bad but that is why I went with the procharger so I did not have to worry about filling bottles and being ilegal with a nitrous bottle in the car.
The Following User Says Thank You to bigblockragtop For This Useful Post:
454 blower philboy Engine 3 10-22-2012 01:22 AM
454 blower set up 1990k1500 Hotrodding Basics 9 06-11-2012 05:46 PM
stock 454+blower=???? drummer_joe Engine 15 03-04-2012 04:00 PM
454 deck height and blower ekacpuc Engine 4 03-07-2011 02:54 PM
454 mini blower 81malibu Engine 6 11-04-2009 10:59 AM
