Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 454 blower set up
Old 05-24-2012, 06:54 PM
11echo's Avatar
11echo 11echo is offline
Old Guys Rule!...EVERYTHING!
The two things I'd do if I was you, check the crank to see if it's a steel or cast iron ...obviously steel is the way to go, IF your goal is to make serious HP's! The other issue is rod bolts, I'd replace the stock ones with an after the market set that are readily available ...ARP, Milodon, & etc. Stock rod bolts get abit "stretchy" in high RPMs. Good Luck ...BBC are fun!
