454 build need some good advice - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-22-2010, 03:17 PM
hey everybody I am new to the forum and am in the planning phase for my engine. Well I'm no expert and will be having a local shop do most of the work due to the fact I don't have the tools. I will try to be involved as much as possible. Anyways I have a 454 with 049 heads not sure what is all in the bottom end. It has a holly 750 dp I will be changing the pistons but trying to keep the stock rods and crank. It will be going back into a 72 cutlass with an automatic tranny built for performance and 342 gears. It will be a street car and proubably never see a track maybe once if they talk me into it.I want something that is good for the road but is also a beast when I want to play around. Any suggestiong or advice would be greatly appreciated and as stated before I'm no expert so that is why I have turned to all of you. Thanks again
Old 09-22-2010, 03:26 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Welcome to the site. If you post this in the engine section i am sure someone can help you.
Cole
Old 09-22-2010, 03:29 PM
Yes sir sorry about that I tried to ill get that over there thanks.
Old 09-22-2010, 03:50 PM
poncho62's Avatar
Wiki Edits: 5
moved it...............
454 build Summit bought parts dyno'd tjpounder Engine 3 05-13-2010 04:11 PM
454 build jr2009 Engine 6 05-25-2009 05:58 AM
454 2bolt 289 block or 4bolt 454 1 piece seal to build a 496 heathj1 Engine 2 12-21-2008 10:22 AM
how to build 454 to run propane with 600+HP? propaine rockcrawler Engine 0 03-04-2007 10:12 AM
intake advice for 454 DaSouthWon Engine 23 04-18-2006 09:27 AM
