Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 454 BUILD please help.
Old 09-16-2011, 02:35 PM
6426yy's Avatar
6426yy 6426yy is offline
What transmission and rearend are you running gear ratio also. Everything has to work together. A small dome piston and a set of 049 or 781 large oval ports with some mild port work and a cam is all your gonna need to make it a strong driver. Your cam selection will depend on the rest of the car, auto trans stall speed, gear ratio ect, ect. Need more info!
