Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 454 BUILD please help.
Old 09-16-2011, 04:13 PM
techinspector1's Avatar
techinspector1 techinspector1 is offline
Wiki Edits: 326
HERE'S AN EASY 650 FT/LBS....
Bore block +0.100"
TRW H112CP-100 pistons
http://www.flatlanderracing.com/trwchevyspecial.html
Stock 6.135" rods with ARP bolts, resized.
4.250" stroker crank of your choice. (Scat makes a nice piece)
http://www.summitracing.com/parts/SCA-945420/
Stack = 9.785". Nominal block deck height = 9.800". Use 0.040" head gasket for 0.055" squish.
RHS heads...
http://www.summitracing.com/parts/RHS-11301-02/
119cc heads with H112CP-100 pistons will produce 10.2:1 static compression ratio with a 9.785" stack and 0.040" gasket. Align hone the main saddles and take a light cut on each deck to you know that each corner of the block is the same distance from the centerline of the main bearing bore. The combination I'm showing here assumes a 9.795" to 9.800" stock block deck height.
Edelbrock RPM or Weiand Stealth intake with 850 carb...
http://www.summitracing.com/parts/EDL-7163/
Long tube 2" headers of your choice.
CompCams 11-713-9 solid roller cam....
http://www.summitracing.com/parts/CCA-11-713-9/
RPM HP TQ
2000 195 513
2500 250 525
3000 319 559
3500 404 607
4000 487 639
4500 560 654
5000 615 646
5500 643 614
6000 643 563
6500 593 479
Peak volumetric efficiency 96.9% @5000
Peak BMEP 195.1 @4500
Make 600 ft/lbs with a little less cam, a hydraulic roller....
http://www.compcams.com/Company/CC/c...?csid=445&sb=0
I don't think you will be happy with warmed-over production heads. They're just junk compared to some of the aftermarket heads being currently produced. $779 per head (assembled) seems to me like a heck of a price for a BBC head that makes this much power. My very best advice would be to put the project on hold until you have the money to buy the good parts. Don't blow what budget you have presently and be unhappy with a turd motor.
