454 BUILD please help. - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 09-17-2011, 03:03 PM
havin fun
ford you make me excited about this build lolol i do have 3:42 gear on the shelf.... better?
  #17 (permalink)
Old 09-17-2011, 07:23 PM
Ford Junkie's Avatar
No substitute for cubic inches
Use this calculater to figure gear ratio and engine rpm's.
http://www.ringpinion.com/Calc_RPM.aspx
This is not an O/D engine. it's going to want revs and to gear it for proper driving with an O/D then 1st will be so low it will never see it. Best bet with this much build would be a th400.
I don't have links figued out but copy and paste to browser if it doesn't work.
Tony
  #18 (permalink)
Old 09-18-2011, 05:28 AM
havin fun
awesome, thanks junkie. asl always this forum has been a great help.
  #19 (permalink)
Old 09-19-2011, 10:51 AM
havin fun
super charger.
can anyone identify this super charger? i got it last night and i cant find anything on it. the only numbers i have found on it are 5120726 and 5114442 would this be a decent one to use or is it out of date waste of time stuff?
ID:	58431   Click image for larger version
  #20 (permalink)
Old 09-19-2011, 04:56 PM
Last journal entry: Some More Roll Cage Fabrication
That's a Detroit 671. I wouldn't bother with trying to convert it for a blower on your street car. By the time you buy the bearing plates, front cover, rotor pinning kit, and conversion kit you are around 900 smackers. Then you add in the front drive and intake manifold and you start nearing 2K. Then you have to polish it. I converted the one in my project journal. I spent over a year sourcing parts and polishing. I WOULD NOT DO IT AGAIN. However, the most important reason is that a non teflon tipped 671 on a BBC is a waste of time. You would have to overdrive it to make boost and the benefits would be negated by the extra heat.
If you want a blower get an 871 complete and ready to go. Sell that huffer to guy wanting to build a rat rod.
Good Luck
355 build??'s about compression and build impalaman355 Engine 5 06-06-2011 10:20 AM
better to build? PyroManiacUSMC Engine 24 11-25-2010 08:49 PM
350 sbc build Bonhorst Engine 10 01-24-2010 04:41 AM
USA BUILD vs CANADIAN BUILD? troy norrad Hotrodding Basics 19 02-18-2008 09:57 PM
200-4r experts - build questions - Which core is best to build on? Warrant Transmission - Rearend 7 10-09-2007 07:36 PM
