thanks double vision. i'm assuming your talking about making sure the heads are port matched and blended? i'm not a gear head(probably should have said that in the first post) so as far as heads go i will work them... what about cam, compression where do these types of motors like to come alive at?
thanks |
hp #'s aren't going be good for much other than bragging rights IMHO. A 454 was designed as a torque engine from the beginning, make the most of this and you got it whipped. Friend of mine runs them with great success as he utilizes the good points and forgets the not important stuff. I have no info on how he builds them other than he keeps cam size down so he doesn't have rev the snot out of them, but I do know he surely hurts a lot feelings with them and doesn't turn them over 5500 rpm's doing it.
Just food for thought, what do you have in the camaro already as far as suspension and transmission? |
Meaning you get it making maximum torque and let the HP #'s fall where ever you'll be smoking tires or breaking parts. Hard to beat a solid built BB for raw seat of the pants power.Tony |
ohhhh lol ok gotcha. so it will be a fast get up and go car. sorry guys i got into wrenching a little late in life and no dad around so i'v definitly been going through a learning curve. but for 34 i feel like a kid again building these motors
lol this will be my 3rd one, 2nd solo build
I haven't actually worked on a 454 but who ever told you they were a waste of time, doesn't know what they are talking about.
If you are looking for a great Street and Strip Motor or a Drag Motor they are great engines. http://www.youtube.com/watch?v=c8FCNZXyEJY For this article not sure how accurate it is but it says you can get 700HP out of a 454 for around $3000 http://www.superchevy.com/technical/...d/viewall.html Car Craft is always good http://www.carcraft.com/techarticles...d/viewall.html |
What transmission and rearend are you running gear ratio also. Everything has to work together. A small dome piston and a set of 049 or 781 large oval ports with some mild port work and a cam is all your gonna need to make it a strong driver. Your cam selection will depend on the rest of the car, auto trans stall speed, gear ratio ect, ect. Need more info!
HERE'S AN EASY 650 FT/LBS....
Bore block +0.100" TRW H112CP-100 pistons http://www.flatlanderracing.com/trwchevyspecial.html Stock 6.135" rods with ARP bolts, resized. 4.250" stroker crank of your choice. (Scat makes a nice piece) http://www.summitracing.com/parts/SCA-945420/ Stack = 9.785". Nominal block deck height = 9.800". Use 0.040" head gasket for 0.055" squish. RHS heads... http://www.summitracing.com/parts/RHS-11301-02/ 119cc heads with H112CP-100 pistons will produce 10.2:1 static compression ratio with a 9.785" stack and 0.040" gasket. Align hone the main saddles and take a light cut on each deck to you know that each corner of the block is the same distance from the centerline of the main bearing bore. The combination I'm showing here assumes a 9.795" to 9.800" stock block deck height. Edelbrock RPM or Weiand Stealth intake with 850 carb... http://www.summitracing.com/parts/EDL-7163/ Long tube 2" headers of your choice. CompCams 11-713-9 solid roller cam.... http://www.summitracing.com/parts/CCA-11-713-9/ RPM HP TQ 2000 195 513 2500 250 525 3000 319 559 3500 404 607 4000 487 639 4500 560 654 5000 615 646 5500 643 614 6000 643 563 6500 593 479 Peak volumetric efficiency 96.9% @5000 Peak BMEP 195.1 @4500 Make 600 ft/lbs with a little less cam, a hydraulic roller.... http://www.compcams.com/Company/CC/c...?csid=445&sb=0 I don't think you will be happy with warmed-over production heads. They're just junk compared to some of the aftermarket heads being currently produced. $779 per head (assembled) seems to me like a heck of a price for a BBC head that makes this much power. My very best advice would be to put the project on hold until you have the money to buy the good parts. Don't blow what budget you have presently and be unhappy with a turd motor. Last edited by techinspector1; 09-16-2011 at 03:35 PM. |
great advice guys, techinspector you always go that little extra in your post's thanks. i'm not planning on putting this in the car till spring so by then maybe i will have a little extra dough to buy some better heads.
as far as whats going to be supporting this car. this is what i'm planning on doing and by spring i should be able to pull it all together. "monster" performance 700r4.. sorry i hate 3 speed transmission. i know the 350th and 400th would be stronger but i have to have overdrive. 3:08 mini spool rear. little better then stock suspension depending on what build i go with maybe a small nitrous kit....100 shot. i just sold my other camaro that had 550hp out of an sbc... i want bigger and better lolol |
http://www.hotrodders.com/forum/4l80...ge-183483.html |
If you look at the numbers TI posted you can see what I was talking about.HP doesn't come in till late in the program but is irrelevant because of the 513 ft lbs. at 2000 rpm's, this thing is pulling the house off the foundation from 2000 rpm's up to 6000 rpm's!!!!!!!!!!!!! You can bet the farm you better have some bite on the ground when that 1-2 shift comes in or this things going for the sidelines.Tony |
agreed sounds like a nice set up. can anyone elaborate on the 4l60e thing i mx commented on? and thanks mx for the tip. would i need a computer for that? etc. i should be getting my motor tomorrow (sunday)
thanks guys. |
3.08 gear and an od trans will kill the driving of this car. Your talking on a 26" tire of turning 1800 rpm's at 65 mph, this engine would be lunging on the cam at this rpm under load. I am guessing this thing is going to want to cruise around 2500 to keep cylinders clean.>>>>little better then stock suspension<<<< It better be a lot better than stock if you really want this kind of power. Your 550 hp small block won't even compare to this in a good dream................. |
| 355 build??'s about compression and build | impalaman355 | Engine | 6 | 06-06-2011 10:20 AM |
| better to build? | PyroManiacUSMC | Engine | 24 | 11-25-2010 08:49 PM |
| 350 sbc build | Bonhorst | Engine | 10 | 01-24-2010 04:41 AM |
| USA BUILD vs CANADIAN BUILD? | troy norrad | Hotrodding Basics | 19 | 02-18-2008 09:57 PM |
| 200-4r experts - build questions - Which core is best to build on? | Warrant | Transmission - Rearend | 7 | 10-09-2007 07:36 PM |
