454 build Summit bought parts dyno'd - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-04-2010, 12:12 AM
tjpounder's Avatar
69 Nova SS 454
Ok Gang lets try this again. This 454 .30 0ver engine will be going on dyno this week. I just bought the car and this is the engine it came with and the information on what is in the engine was provided by previous owner. it is a fresh build with less than 300 miles. All parts I list were purchased at Summit and total about $2110.20 USD . The car is a 1969 Nova with a 3:73 gear turbo 350 11" 3200 stall but more like 4000, very loose. The engine is not fully tuned yet but it's not bad (but what do I know). I have been driving it for a couple of days and if I could get a little more out of it I might be satisfied. It's just for fun. I won't be taking it to the track but I will get on it every now and then.Mostly used for running around town and short hwy trips (runs 3000rpm @ at 60mph) 100-150 miles per week . At this point It runs fairly good but it is obvious that there is more available so we'll see how much in the before and after dyno numbers. I don't have engine block or cast head casting numbers yet but i would say oval port heads cc may or may not be worked. Headman ceramic coated headders,mechanical fuel pump (Holly about $100) I will post the dyno numbers next week. If I missed anything its been a long day. I will be calling the original engine shop/builder on Wed. to try and get more information.if you need more info just ask in a post. If this post helps anyone then my time well spent if not then it's just another example of me thinking I know whats going on. Please feel free to do a little reasearch on Summits web site for all the specs. then take your best guess on dyno numbers for Forum bragging rights if you want. I am posting part description and numbers in this order:
Brand:
Manufacturers part #:
Part type:
Product line:
Summit Part #:
Here Goes:
1) Eagle
104544000
Crankshaft
Eagle Cast Steel Crankshaft
ESP-104544000
2) Keith Black Pistons
KB202-030
Pistons
K/B Hypereutectic Pistons
UEM-KB202-030
3) Sealed Power
ZR990530
Piston Rings
Sealed Power Ring Set
SLP-R990530
4) Scat
310198922
Connecting Rods
Scat replacement I-Beam
SCA-310198922
5) Summit
Camshaft and lifter kit
Summit Cam and Lifter kit
SUM-K1302
6) Comp Cams
2110
Timing Chain and gear set
Comp Magnum Double Roller
CCA-2110
7) Comp Cams
7854-16
Pushrods, assembled
Comp Cams High energy pushrods
CCA-7854-16
8) Edelbrock
5895
Valve spring & Retainer kit
Edelbrock Sure seat vs kit
EDL-5895
9) Summit
SUM-V8022-8
Valves in.
Summit Race valves for Chev
SUM-V8022-8
10) Summit
SUM-V8030-8
Valves ex.
Summit Race valves
SUM-V8030-8
11) Edelbrock
2904
Intake Manifolds Carbureted
Victor Jr
EDL-2904
12) Summit
SUM-M08750VS
Carburetors
Summit Street/strip carb
SUM-m08750Vs
I don't think I will be using this carb but will be doing pulls with it and with a second carb that the engine shop has recommended. I will post dyno numbers for both and the manufacturer name and specs on the second carb (also 750cfm) to show the difference.
13) Summit
SUM-850055
Distributors
Summit Street strip billet dist.
SUM-850055
Speed Costs Money. How Fast Do You Want To Go?
Regards
Old 05-12-2010, 02:58 PM
starnest's Avatar
elkyholic
Last journal entry: Center Link Installed
This is not enough info to really zero in on.
I think your pistons (flat/slight dish) have you at about 8.7:1 compression at best with the closed chamber heads (109cc).[Unless someone cleverly milled the heads to reduce the chamber volumes - but even that wouldn't get you past 9:1 compression] Compression would be much less if you have open chamber heads (cast 049:115-118cc or cast 049:122cc)
Without looking up the cam specs, most high lift cams will have too much duration, so you are limited on high rpm horsepower; which also means you are not going to match up well with the victor intake.
I'm going to guess that you are at about 280hp. The good news is you should still pull some pretty good torque numbers, lets say around 350lbft.
Old 05-13-2010, 02:50 PM
starnest's Avatar
elkyholic
Take a Guess - How many horses?
Maybe a different title will stir some interest.
Old 05-13-2010, 04:11 PM
tjpounder's Avatar
69 Nova SS 454
"69 Nova 454 going on dyno lets hear your guess" is main post
454 build - up ... opinions? 66GMC Engine 14 04-25-2011 08:46 PM
Just bought 400 chevy, build idea and some questions? Warrant Engine 10 01-11-2006 06:50 AM
anyone use summit brand parts? malibu68 Engine 14 12-12-2004 05:18 PM
How can I build a 454 "POWER" Engine? stevecollins Engine 3 08-07-2004 07:55 PM
Bought the parts donor truck today... DesertPanel Hotrodders' Lounge 0 11-02-2003 08:12 PM
