Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 454 build up
Thread: 454 build up
Old 08-18-2012, 03:10 PM
vinniekq2's Avatar
vinniekq2 vinniekq2 is online now
I wouldnt use the rectangle heads unless you are serious about power. Ported GM oval ports with 2.19 valves make a fair amount of power. then after market ovals then squareports. If you already have the heads,put them on a flow bench before buying a cam.
