Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 454 build up
Thread: 454 build up
  #25 (permalink)
Old 08-20-2012, 12:34 AM
vinniekq2's Avatar
vinniekq2 vinniekq2 is offline
If you follow cdminter59 s advice,I would advise you to make friends with the local tire retailer as that engine will wear them out almost as fast as you can empty a few tanks of gas.If the rods are 3/8s and you limit the RPMs under 7k you probably will be fine,make sure you buy the good ARP replacement bolts
