Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 454 build up
Thread: 454 build up
  #31 (permalink)
Old 08-21-2012, 05:19 AM
454C10 454C10 is offline
You need more gear and compression for a 500hp 454 in a heavy truck.
The cam you have is already too much for a 2.73 gear and compression in the mid 7's. And tall tires will make that worst. Plus a higher stall converter will be needed.
If you don't plan to increase compression, add more gear and higher stall, then add boost to make your HP goals. And use a smaller cam that matches the gear and stall.
