Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 454 build up
Thread: 454 build up
  #33 (permalink)
Old 08-21-2012, 12:05 PM
cdminter59 cdminter59 is offline
3919840 heads
The 3919840 heads are 1967-69 396/375hp, 2.19/1.72 valves, 106.8 chambers. If the exhaust valve is 1.88 they are 1967-1970 427ci heads. Check them out on ebay. Complete they are selling for $1000-$1500. They are a closed chamber head but would work on a 454 with flat top pistons. You would have to check piston to valve clearance. Compression ratio 8.912.
The Following User Says Thank You to cdminter59 For This Useful Post:
Horsepoweraddiction (08-21-2012)
