454 build up - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-17-2011, 07:52 PM
454 build up
Hello guys, here is my wuestion, i got a 454 long block out of a 1986 chevy 2500, since i already have some stuff im just wondering what i can use and what i cant.
the block is stock, i got this from a friend ,(out of a boat)215 oval port heads with the heavy duty triple valve springs,comp cams magnum 286h ,holley strip dominator oval port, i dont really want to overbored the block because i dont have extra $ to spend at the moment. this engine will be in a 1973 camaro with 4 speed muncie and 3.42 rear end gears.
thanks!!
Old 05-17-2011, 08:18 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi
Welcome to Hotrodders.com Glad to have you with us.
That's a rather large cam, should be about right for the track.
Rich
Old 05-17-2011, 09:20 PM
is it? what would you recommend? thanks!
Old 05-17-2011, 11:08 PM
Hi
Comp Cams 'Magnum' Hydraulic Flat Tappet Camshafts 270H or 280H
The 270H won't affect your power brakes..510" L 270*D
I would use the 280H .520"L 280*D
Rich
Old 05-17-2011, 11:25 PM
techinspector1's Avatar
Wiki Edits: 326
I wouldn't change anything until I knew more about the motor, like static compression ratio and piston deck height. You can't just reach out in the breeze and grab a cam without knowing what the motor wants. It might be just outside detonation right now and a shorter cam could push it over the limit for cylinder pressure on the available fuel. You just don't know until you measure the motor and know what you're dealing with. That's the way I see it.
Old 05-18-2011, 08:41 PM
thanks guys, yes the short block is stock with the peanut port heads the CR was about 8.5 probably?but took off the heads trying to install this 215 with the bigger ports, the pistons are flat top, i don't know the CR yet because i haven't installed the heads, the camshaft,the heads, the intake, 750 cfm holley carb, this stuff came out of a jet boat and i only want to know what should i use since i already have them. my friend told me that milling the heads and getting the 1972 gm ls6 .022 head-gaskets increases the CR a little bit i been searching those gaskets and no one have them. are there any equivalent?
thank you again!!
Old 05-18-2011, 08:53 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Installing the heads isn't going to tell you anything about the c.r., you need the bore, piston type, dome/dish in cc's, valve reliefs or not, combustion chamber volume, deck height and gasket thickness to compute it.
Have you tried COMETIC for gaskets? They're pricey, but will make anything you want in MLS.
Semper Fi
Old 05-18-2011, 10:11 PM
Hi Jooe
At the link it will explain how to calculate your compression ratio
Rich
http://www.circletrack.com/techartic...ion/index.html
Old 05-19-2011, 12:36 AM
thanks guys rich, i see that my CR will be 9.1 ill sell the strip dominator,will the weiand stealth intake work as the edelbrock rpm? just wondering to save $, was looking on the cams specs and at least needs 9.5.1 CR, ill check Mr. gasket products, do you have a part #?
Old 05-21-2011, 10:07 PM
Hi Jooe
I've been gone (on the road) for a couple days, happens often.
Use the Stealth it has larger runners. How's everything else going?
Rich
Old 05-21-2011, 10:53 PM
Wiki Edits: 326
You can't buy the original style Stealth anymore, unless you find one used. The current part number has an "S" behind it, indicating Street and it is not the same manifold that we have come to love in the past. Want the real deal? Buy an RPM.
Old 05-21-2011, 11:20 PM
Tech I'm surprised at you, he has the stealth already & is trying to save some money.
Rich
Old 05-22-2011, 09:26 AM
should run ok with 9:1 cr with than cam (286H). More compression would be nice but not completely required in your case.
A 4 spd manual trans, 3.42 gear in a 73 camaro with a 454 can handle some parts mismatch and run decently.
I would prefer a 270H with that setup but I tend to undersize my cams because I like good street manors. A 280H would work about the best overall, but not a big enough difference between the 280H and 286H to justify a cam swap.
I like the regular RPM intake (not air gap). But I'm sure the stealth will work fine if you are on a budget.
This engine will like lots of initial ignition timing due to the cam size, lowish compression, and engine design (454 bbc with slow burn heads). say, 25-30 at idle and 40 total.
Old 05-22-2011, 10:09 AM
Piland Triangle, Elroy, TX
Boat motors often suffer from freeze damage. Inspect the block carefully for cracks & damage. I would pressure check it before investing in it. I hope all is well -Good Luck on the build!
Old 05-22-2011, 06:39 PM
i really appreciate your advice guys, well i'll try to sell this intake and the camshaft,vexzer the block wasn't in a boat, just the intake, car and cam, well the heads factory are 109 cc's but i think this guy installed bigger valves he replaced the heads for a set of brodix and a bigger camshaft,however, it seems that keeping the 280 h will affect my brake system, so , 9:1 CR rpm intake, 270 h or 280 h? 750 holley carb, i also have an accel electronic distributor with the yellow coil, used but its in great conditions should i use it? holley fuel pump, if i buy the 270 h camshaft do i have to buy new lifters, pushrods. and springs? or the ones that came with the 286 H will work? thanks !
400 SBC build djohnson308 Engine 9 09-30-2015 11:34 AM
USA BUILD vs CANADIAN BUILD? troy norrad Hotrodding Basics 19 02-18-2008 09:57 PM
200-4r experts - build questions - Which core is best to build on? Warrant Transmission - Rearend 7 10-09-2007 07:36 PM
build or buy captberke General Rodding Tech 5 08-30-2006 10:21 PM
want build my own newbe Transmission - Rearend 2 03-25-2006 05:52 AM
