454 build up - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 08-18-2012, 04:57 PM
vinniekq2's Avatar
to vague of a description?IDK?
  #17 (permalink)
Old 08-18-2012, 05:30 PM
454 build up
What plans do you have for this truck? Do not buy any more parts until you know what your plans are. For street use the 781 and 049 (casting numbers) oval port heads are the most popular. You would need to cc the chambers so you can figure your compression ratio. Most rectangular port heads are used on engines for racing. Is this truck going to be a daily driver?
  #18 (permalink)
Old 08-19-2012, 10:03 AM
And could you give me the part number for the correct intake I should get from summit? Thanks
  #19 (permalink)
Old 08-19-2012, 10:37 AM
It's going to be like a weekend warrior, racing Just about every chance it gets but I want it to do good as a daily driver also, just pretty much be a monster on the street and pretty good on the track.
  #20 (permalink)
Old 08-19-2012, 10:39 AM
vinniekq2's Avatar
If the engine is already balanced and blue printed,then install it and go racing.bolt ons only take a day,,,get going,race it.
  #21 (permalink)
Old 08-19-2012, 10:51 AM
No I just got cam n headers that's all, just wondering what other bolt ons would make it perform at it's best
  #22 (permalink)
Old 08-19-2012, 10:59 AM
vinniekq2's Avatar
there are no perform at its best parts. The parts are all different because we all have different requirements.When you know what you want we can help more,have fun racing
  #23 (permalink)
Old 08-19-2012, 12:35 PM
This is my first ever build, and I don't know everything, but I'm learning and I need all the help I can get. All I want is a truck I can race a little but still drive it on the road. My budget isn't the best but I'm willing to work a little. That's why I want to know what the right thing is to get because I have had no experience with motors before a year ago. I'm just looking for the best for what I got.
  #24 (permalink)
Old 08-20-2012, 12:03 AM
454 build up
Let me suggest an engine build. I will try and stay budget friendly, but this is a big block. Take the block, crank, rods to a machine shop to have them checked. If everything is good have the block bored .030, have the crank polished. The rods will have to be reconditioned. I hope they have the 7/16 rod bolts. Have them install new ARP bolts. Try and sell or trade your heads for a set of 781 oval port heads. Make sure the 781's haven't been butchered, you need 118 cc chambers so ask if they have been shaved. A good set of pistons is IC779 from Keith Black, they are forged. With 118cc heads they make 9.621 compression. For a camshaft I have 2 in mind. Both are mechanical flat tappet. 402ALUN .550/.570 lift and 238*/248* duration. Basic operating rpm range is 2400-6800. CRN 133841 .544/.567 lift and 238/248 duration. Basic operating rpm range 3000-6500. You will also have to purchase the solid lifters and spring set for the cam you decide on. I like the Lunati 402A2LUN. Intake Edelbrock 2904, Carburetor Speed Demon 850 1563010VE. The machine shop will also have to install springs on the heads. I am thinking of around 550 hp.
  #25 (permalink)
Old 08-20-2012, 12:34 AM
vinniekq2's Avatar
If you follow cdminter59 s advice,I would advise you to make friends with the local tire retailer as that engine will wear them out almost as fast as you can empty a few tanks of gas.If the rods are 3/8s and you limit the RPMs under 7k you probably will be fine,make sure you buy the good ARP replacement bolts
  #26 (permalink)
Old 08-20-2012, 07:04 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Before buying an intake, you first need to see what the casting number of the heads that are on the engine now to know where to go next, as far as buying parts goes.
There's a decent chance you have what's called "peanut port" heads. They make a lot of torque down low but not a lot of HP up higher in the rev range. The only intake I know of that's made specifically for the PP heads is Weiand's - p/n 8122 Street Warrior. For oval port heads, use Edelbrock p/n 7164 RPM intake.
If you want 500 HP, you'll need a set of oval port heads like the 049 or 781. Adding larger valves will help, but not absolutely necessary unless you're going to get serious- and if THAT were the case, I'd say to save up for a set of aluminum aftermarket heads.
  #27 (permalink)
Old 08-20-2012, 09:31 AM
I have 3 sets of big block heads 1. 3856206. 2. 4081045 3. 346236 so I take it all of them are peanut ports? And 550 sounds great but I cant, definitely in the future ! But if those heads aren't the oval ports I need imight can try and find a set of the 049 or 781s. But if I can't get any I'll take vinnies advice and get the bigger valves and port a set of them.
  #28 (permalink)
Old 08-20-2012, 06:06 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The 236 are PP. I think the 045 are too.
The 206 heads (below) are closed chamber oval port heads. They will bring the compression up, but they don't flow as well as open chamber heads. The open chamber heads require a domed piston to bring up the compression.
There's an "in between" head called a semi-open chamber, like the casting number 215 and 063 heads. They are about 100-103cc. Open chamber heads are around 118cc.
Semi-open chamber on left, open chamber PP heads, right
  #29 (permalink)
Old 08-20-2012, 06:27 PM
Cridder's Avatar
Last journal entry: 310 Small Block Chevy
Edelbrock Performer on BBC a poorboy
Originally Posted by vinniekq2 View Post
please do not use a dual plane intake, I took a performer off my 454 Camaro and installed the vic oval port and picked up 4/10s,,,, wow!!!.
My experience with the performer On BBC is smiler, even with port matching (fair amount of grinding required) it was a wezzer, strictly for stock replacement not performance enhancement. the Weiand IMO is a way better dual plane.
I see theres a preformer "RPM" available now, thks cobolt, that would probley be more of a upgrade.
Last edited by Cridder; 08-20-2012 at 06:43 PM. Reason: Clarification = dope on spin
  #30 (permalink)
Old 08-20-2012, 08:08 PM
454 build up
Horsepoweraddiction, Can you give me the casting # off the rectangular port heads. I want to find out the chamber volume and port size. I have been looking online but there are too many heads with different size chambers. I was reading a couple articles comparing rectangle ports and oval ports. The oval ports performed better on the low end rpm but the rectangle ports caught up on the high rpm end. If you had them and money is a problem why not use them until you can afford something better?
454 BUILD please help. v8mazda Hotrodding Basics 19 09-19-2011 04:56 PM
454 build hp??? 1fast62 Engine 26 02-15-2011 10:02 AM
454 2bolt 289 block or 4bolt 454 1 piece seal to build a 496 heathj1 Engine 2 12-21-2008 10:22 AM
454 Build black66 Engine 2 07-23-2005 11:41 AM
454 Build Up BIG BLOCK DREAMS Engine 3 08-23-2004 05:09 AM
