3919840 heads
The 3919840 heads are 1967-69 396/375hp, 2.19/1.72 valves, 106.8 chambers. If the exhaust valve is 1.88 they are 1967-1970 427ci heads. Check them out on ebay. Complete they are selling for $1000-$1500. They are a closed chamber head but would work on a 454 with flat top pistons. You would have to check piston to valve clearance. Compression ratio 8.912.
| The Following User Says Thank You to cdminter59 For This Useful Post: | ||
Horsepoweraddiction (08-21-2012) | ||
Yeah I have flat top pistons and I'm sure they will work because the guy I bought it from was planning on putting them on a 454 , And would that campare with a set of the 071 heads? What could I do to get the compression higher?
You know they have to many websites that have the wrong information. I just looked that info up last night on nastyz28.com. 454C10 would you be able give an answer. Will the 454 Vortecs heads work on the early bigblocks with flat top pistons like they do on early small blocks? Anybody else?
I run a set of 781's on my 454 and they are 120cc. So, I didn't need to look it up in this case. I also use a small dome to get it up to 8.75:1. Flat tops are the stock smogger piston in a 454.
I also have a set of 820's from a 73 402, and they measure 112cc. These are also good heads that would increase the compression in a flat top 454. I heard the votec head will work on old BBC blocks, but I have no experience with those. I also read they are good heads and the low engine output from vortec 454 is due to the poor cam and intake. |
the price sounds about right. Maybe a little high. But if they are in really good shape then ok.
I hope you are buying them locally, as they would be very expensive to ship. |
I'd have it writen up that they going straight to be magged, and if fail the test you get your green back..
You don't need anything special. Just a plain hyper pistons would do the trick.
If you are still planning on using a xe274 cam then look for a piston that will make 9 to 9.5:1 cr i a 454 with 120cc chambers (781 heads). I recommend the old school 280H cam if you go with a flat tappet cam, as it is less likely to go flat than the XE cam. |
| 454 BUILD please help. | v8mazda | Hotrodding Basics | 19 | 09-19-2011 04:56 PM |
| 454 build hp??? | 1fast62 | Engine | 26 | 02-15-2011 10:02 AM |
| 454 2bolt 289 block or 4bolt 454 1 piece seal to build a 496 | heathj1 | Engine | 2 | 12-21-2008 10:22 AM |
| 454 Build | black66 | Engine | 2 | 07-23-2005 11:41 AM |
| 454 Build Up | BIG BLOCK DREAMS | Engine | 3 | 08-23-2004 05:09 AM |
