But there's little if any difference in the actual performance between the two if they are both set up properly- at least until the cast/cast hypereutectic piston reaches the point of no return, a point which will be found sooner than a forged piston. Just be sure to fully warm the engine up before hammering on it w/forged pistons. That gives them time to expand closer to their running dimensions where the ring seal will be better because of less piston rocking. But if you plan on nitrous, forged gives a lot more leeway in case of detonation. Detonation can kill ANY piston when running nitrous, but a cast hypereutectic piston will literally shatter whereas a forging will tend to go down in one piece for the most part unless the detonation is ignored. And it may even survive if the detonation isn't that severe. Nitrous is very demanding on an engine. Aftermarket rods might be in order because I do not know of anyone who has been satisfied w/a "small" shot of N2O. At the VERY least, the rods need to be magnetic particle inspected, new ARP hardware installed, and then resize them. There are ignition boxes that will pull out timing to keep the engine safe; if I were to build a serious nitrous engine, you can bet I would be running one. Not really necessary at the lower levels, but even then the timing can be run higher when not using nitrous- which equates to better performance when on or off the bottle. When you get to the >250 HP stage, think about better rings/ring material. Even at low doses, plasma moly is the minimum because moly inlay can chip off the ring. 250 HP and up forged isn't an option IMO, although you'll hear guys who get away w/it. Trouble is there's NO leeway if the tuneup is off, or a fuel pump problem comes up or for any number of things. This barely scratches the surface but will give you some things to think about. There are guys here w/more experience using nitrous than me, hopefully they will be along shortly. |
I'm not even considering going with 250 or more. My motor could easily handle a 250 shot, but I would need to upgrade my fuel system to be safe. I don't really care to do that. I have no goal or reason to try and go faster. My truck is super strong just the way it is. I have fun with it. That's all I need. There comes a point when you just get tired of spending money and working on it all the time. I'd rather just drive it and have fun. It is what it is. I have satisfaction in building it myself. I don't have to be the "fastest" in order to have pride in my work.
Don't be so focused on a certain peak HP number.
Trust me, you will be happier with a strong torque engine that pulls hard from down low through the midrange. That is what you "feel" when you nail it. Throttle-response and torque gets you rolling. I would rather have a Big Block that makes 500 torque at 3800 RPM and 480hp at 6,000 than one that makes 200 torque at 3,500 RPM and 520hp at 6,500. You just pick your tire size and rear-end gears to match the torque curve, and you are all set to rock. You don't have to run as much converter stall either. It's a win-win deal. |
Man you are right and nitrous would do what i needed it to do at times. but i own 3 454s and they need building haha. but for the one currently in my truck i am satisfied with it 'for now' but i will build me one with mech roller and so on and so forth. i'll further gather my knowledge and see what i come up with man. Thanks for commenting man. i got this 496 i been wanting to build haha.
LOVE the 540. Love the 632 even more.
But now you are in the world of big-money. Can't get 540 cubes from a stock 454 block. And with that many cubes, big port aluminum heads are a must. Only problem with running bigger than a 502 on the street is the darn things drink GAS! I love big-inch motors, but you can't drive past a gas station. Gotsta keep it "streetable". I doubt I could get a 632 to hook up on the street anyway. ( Funny car slicks with some grooves cut in them? )
The 540 option is like the 434 option in small blocks,the price is decent,you dont have to use a tall deck like the 632, street able 675 hp 540s are common and can put any car deep into the 11s. all with a single 850 and hydraulic cam.
Gas mileage is figured by sfc and gearing/average speed,,,,,,etc. Gas consumption will start at lots and go upwards |
454 build up
Horsepoweraddiction, You say you have (3) 454 motors. For now build a mild streetable 454 for your truck. Take a block, crank, rod & pistons, and your 781 heads to the machine shop. Have the machinist check the block, then have it dipped, bored & honed, install new cam bearings, freeze plugs, screw-in oil gallery plugs, and deck the block. Have the crank checked, if ok have it polished. Have the pistons removed from rods, install Arp rod bolts and then have rods resized. Purchase Keith Black Icon Forged Pistons part# IC779 at CNC Motorsports for $510.95, Jegs $649.99, Summit Racing $719.95 and have them installed on rods. Have your heads checked out and don't forget to have the matching springs for your XE274H-10 camshaft installed. With a build like this it will be strong enough for the 100-150 shot of nitrous to get you to 550hp.
Wow those pistons are that much cheaper at CNC motorsports? And yeah I'll probably do something like that. Seems to be the best route until I build that 496 haha. I'll be building that race motor then boys.
| 454 BUILD please help. | v8mazda | Hotrodding Basics | 19 | 09-19-2011 04:56 PM |
| 454 build hp??? | 1fast62 | Engine | 26 | 02-15-2011 10:02 AM |
| 454 2bolt 289 block or 4bolt 454 1 piece seal to build a 496 | heathj1 | Engine | 2 | 12-21-2008 10:22 AM |
| 454 Build | black66 | Engine | 2 | 07-23-2005 11:41 AM |
| 454 Build Up | BIG BLOCK DREAMS | Engine | 3 | 08-23-2004 05:09 AM |
