454 Cam - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-17-2010, 11:48 PM
chevykid90's Avatar
454, what turns your crank?
Last journal entry: Replacing bearings and crank
454 Cam
ok so i am building a mostly stock BBC. i have 049 heads with the stock valves, and will maybe do a mild port. the block has been bored .030, with flat top pistons. and i think that my gears are 3.08's. its stock 81 firebird and i couldnt find any information on what size the gears may be. but i know it has a posi and its a 10 bolt. so now my question is that what size cam would be best. i am not trying to build a monster but i want it to have more power and torque than stock. its for the street so i would like the power band to be in the lower RPM range, not planing to go over 5500. any input would be helpful. thanks.
Old 06-18-2010, 01:46 AM
DoubleVision's Avatar
The rear gear is a GM 8.5
Since you`ve laid out your plans, this is a no brainer decision. A edelbrock performer camshaft is all you need. It provides a smooth idle, great low end torque and it`s powerband goes to 5500, ideal for your purposes.
If the car has T tops, and even if it don`t, Installing some subframe connectors would be a good idea.
Old 06-18-2010, 10:48 AM
chevykid90's Avatar
thank you for the reply. my car doesnt have t-tops. and i will be someday beafing up my frame and my rear end for a monster stroker big block that i will someday build. but you have to start some were right? lol
Old 06-18-2010, 12:53 PM
I`d install sub frame connectors with the next to stock big block your installing. These cars like to flex, especially after they get older. My 79 Z28 flexed with a small block and it did it`s share of damage.
454 intake & crossover & cam ekacpuc Engine 1 04-25-2010 04:36 PM
Roller Cam / Lifters in Gen IV 454 Block 31fordcoupe Engine 2 03-12-2009 07:08 AM
454 cam help?! 1967chevelle454 Engine 3 01-25-2009 01:18 AM
454 cam custom56chevy Engine 0 10-25-2007 04:34 PM
What cam for 454 ci? orian Engine 4 01-27-2007 10:04 AM
