454 cam question - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-09-2010, 03:46 PM
truckboy61's Avatar
454 cam question
Is there anything that holds cam from walking forward ? This one only has timing chain sprocket and lock
Old 11-11-2010, 01:04 PM
mud.man.rj's Avatar
cam walker
AS the distributor gear turns it pulls the cam back in the block.
Old 11-11-2010, 01:16 PM
BOBCRMAN@aol.com's Avatar
As mud.man said,, plus the lobes of a flat tappet cam are ground with a very slight angle. This also forces the cam to the rear. Only a roller cam needs the camshaft retained by other pieces...
Old 11-11-2010, 03:09 PM
yes, slight angle on the flat tappet lobes to push the cam rearwards.
Old 11-11-2010, 03:19 PM
Another little tid bit on this subject.. I see a lot of stock BBC blocks that have used high volume high pressure pumps (M77HV). Combined with heavy oils, wear the front cam gear thrust area badly. This a common problem, the pump is trying to pull the cam back with a vengeance. The fix is easy. Plus there are wear plates available to repair damaged blocks.
454 Cam RPM question 454headache Engine 2 03-30-2010 12:28 AM
street/strip 454 cam and head ?'s High School Hot Rod Engine 3 03-23-2010 02:10 PM
Comp Cam Question crystalbluevib Engine 5 03-03-2010 07:25 PM
Comp cam change gear Question solidaxel Engine 9 08-27-2006 08:13 AM
another dumb cam question jesse01 Engine 15 06-22-2005 02:07 PM
