454 Casting Number - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-28-2008, 03:54 PM
chevy bb 572's Avatar
CHEVY BIG BLOCK 572
Last journal entry: sum rides i got
454 Casting Number
HAVING PROBLEMS DECODING 454 MOTOR. I WENT TO A FEW WEBSITES MORTEC ETC. I NEVER SEEN 5 NUMBERS ON THE BACK OF ENGINE BLOCK USEALLY 6 OR MORE CAN ANYONE HELP 38959 THATS IT NO MORE ALL NUMBERS ARE CORRECT. PLEASE HELP
Old 09-28-2008, 05:11 PM
SSedan64's Avatar
You're missing 1 or 2 numbers. Also 3's, 8's & 9's are hard to tell apart on casting numbers. Does your block have a Suffix code on the front passenger side deck pad of the block? Just in front of the head.
Old 09-28-2008, 08:02 PM
CHEVY BIG BLOCK 572
454 casting numbers??????????
yes thats all the the numbers no numbers on the front pass pad below the alt. ive got the motor pulled, cleaned,painted ive got nothing. i had a few other guys double check the numbers thats them 38959. may be a dump truck block? idk
Old 09-28-2008, 08:36 PM
prostreet6t9's Avatar
Differential/Driveline
3855961....396.......65-66...2 or 4 bolt
3855961....427.......66......2-bolt
those are the only 2 numbers I see even close to it, are you sure yours dont start with 385 instead of 389?
Old 09-29-2008, 07:21 AM
CHEVY BIG BLOCK 572
454 casting numbers
thanx but im 8 x sure tha back of the block is 38 959. it like its missing a number or even two. on top of tha is stamped cm 10 T.the pass back side is stamped f 21 77 may be it its a tall block i got nothing elese.
Old 09-29-2008, 07:48 AM
Last journal entry: Bringing home the 401 Nailhead
How about:
361959.....454.......73-90...2 or 4 bolt
Possible that 38 is really a 36? Maybe missing the 1?
Just throwing this out there.
Look at the Pics of my 454 - What the Heck is it? leejoy Engine 17 12-24-2007 06:26 PM
casting number 3970010 rphillips Engine 12 07-28-2007 02:02 AM
Building A 302 Chevy Scorpio Shaping Flow Hotrodding Basics 6 01-16-2007 06:55 AM
help! i cant find this casting number story Engine 5 12-02-2006 12:28 PM
Differential Casting Number? lwin517 Transmission - Rearend 1 09-01-2006 10:54 PM
