454 chevy big block ????? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-18-2009, 04:37 PM
life is a temporary assignment
I just picked up a 454 Chevy for my next truck build.Wanted to know..It has the two ports for a oil cooler bye the oil filter.They are made into the block.I ran the ##'s And it say's it's a 91 and up 4 bolt..What I would like to know is..Can these ports be blocked off ?
Old 05-18-2009, 05:26 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
I don't know if they can be blocked off or not , but you can use a piece of U shaped tubing w/fittings to connect the two ports together,
in case it's plumed to be used only with a cooler.
Rich
Old 05-18-2009, 05:52 PM
Originally Posted by richard stewart 3rd
Hi,
Rich
Thanks Richard..I know I can do that, but would like to block them off if I can.I talked to a mechanic today and he said I could.But I would like to know for sure.Thanks again.
Old 05-18-2009, 07:03 PM
BigBlockT's Avatar
Last journal entry: recessed lisence plate
I would talk with a machine shop that deals with engines or even call summit racing talk with one of their tech's.
Old 05-19-2009, 07:19 AM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
Sounds like you have a Gen V Block-yes, you can block them off-
Old 05-19-2009, 08:01 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If the engine was previously equipped with the cooler, you can remove the oil cooler valves (pressure differential-type, to get the oil to flow into and out of the cooler).
They'll pretty much just pull out, but they might be staked in some cases.
Old 05-19-2009, 11:15 AM
Yes it is..I wanted to say thanks to everyone that responded.I did talked to a few people that build's motor's for a living.And they said the same that you guy's are saying.Look's like I'm good to go.Thanks again everyone..
8.1L 496 vortec big block chevy, what is it? 406 ss monte Engine 20 11-03-2014 11:11 AM
Big Block Chevy combination question JamesRS Engine 13 01-22-2011 07:08 PM
Big block 454 into a 1955 chevy Cal55 Engine 4 03-16-2007 10:07 PM
Two bolt main Big block chevy HTHarry427 Engine 5 06-19-2004 10:23 PM
Big Block Chevy Stroker Kit invincible Engine 3 11-11-2003 06:04 PM
