454 Chevy Engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-08-2009, 10:39 PM
454 Chevy Engine
Hi!
I'm new so bear with me.
I purchased a 1992 Chev 454 engine and am in the process of rebuilding. The engine was mated to an automatic tranny. I would like to go with a 4 speed.
In the Ebay sales, flywheels seem to go up to 1990 and are all externally balanced.
Is my 92 external or internally balanced? If so, does this have to be done in a shop or is the flywheel and harmonic damper designed to only go on one way?
I have a 1950 Chevy Ambulance and would like to mate the 454 to the stock 5 speed tranny. I have no idea if the transmission would handled the torque. I hate to mate them and have the tranny or rear end blow on my first time out.
thanks for any help and I'll be browsing he different posts!
Blanceman
Old 06-08-2009, 10:59 PM
ericnova72's Avatar
More for Less Racer
Can't help you on the balance question, but there isn't any part of the 50 driveline capable of dealing with Big Block power. Stock 50 was maybe 100(?) horsepower straight six. Better plan on changing it all or else drive it like a Grandma to keep from destroying it.
Old 06-09-2009, 06:47 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The engine is externally balanced, the flywheel/flexplate and damper will only fit the correct way, and do not need to be balanced separately- but should be included if you re balance the reciprocating assembly.
An example is HERE.
Old 06-09-2009, 06:51 AM
Banned
you're going to need to swap the rest of the drivetrain, If possible I woul djust get it from whatever car the 454 came from.
Old 06-09-2009, 07:33 PM
BOBCRMAN@aol.com's Avatar
Your 92 BBC is externally balanced. I believe it has a one piece rear seal. You MUST use a flywheel and h-balancer designed for the later one piece rear seal motor. The external balance weight is different than previous 454 BBC's. If not correct you will get a pesky balance induced vibration/shake.
acceleration flat spot in carb. corvettetonybone Engine 17 04-13-2013 08:31 PM
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
Chevy 454 overheating no matter what I do rakundig Engine 26 02-13-2011 04:03 PM
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
Chevy engine bruce b Engine 4 02-14-2005 08:51 AM
