454 Chevy Pump Gas Compression
Howdy
I have a new 454 crate motor with cast iron heads with a 8.75:1 compression ratio. I was wondering how high I could go but still run on 89 octane gas? Thanks |
Depends on cam timing, temperature, and load (gears, trans, weight).
For example. I use a 454, 8.75:1, in a 4200 pound truck, 3.08 gear, th400, and a compcam 260H. It will ping if I pull a light trailer with 89 octane in the summer (95F). If you are running a mild cam (less than 265 degrees advertised) then stay with the 8.75:1. In general, A 268 degree cam can handle 9:1, 270 degree use 9.25:1, 280 use 9.5:1, 290 use 10:1. A BBC will not tolerate compression as well as sbc. |
I also have a 396 out of a L35 Camaro. It has 10.25:1 in it. Will it ping if I put it in a pickup that I tow heavy loads with?
Thanks |
Vince |
| compression ratios and pump gas??? | boatanchors | Engine | 88 | 07-20-2012 10:10 PM |
| the history of chevy v8's | savman1 | Hotrodders' Lounge | 43 | 03-02-2012 06:57 PM |
| Is it normal to have to pump the gas several times to get accelerator pump squirt ? | fumplet | Engine | 3 | 11-16-2010 01:14 PM |
| excessive backfire and flames! also rocker arm knock | chevykid90 | Engine | 53 | 08-27-2010 04:42 PM |
| Fuel Pump Not Sending Gas To Carb Why?? Its Not Electric Fuel Pump???? | zeeman19 | Engine | 7 | 02-13-2007 03:17 PM |
