Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 454 compression test
Old 04-26-2013, 02:55 PM
ss396si's Avatar
ss396si ss396si is offline
Yesterday I installed new felpro gaskets 1047 w/ new ARP bolts. I found a code on the the piston:
H518CP STD 321-0017-a
it has a small dish in the center and 2 slits opposite each other.
Today I did a cold compression test with no rockers and pushrods
1:119
2:121
3:122
4:109
5:89
6:149
7:79
8:145
These numbers are pitiful!
Now 5 and 7 I'm debating if I should retorque the cylinder heads bolts?
6 and 8 have carbon build up.
I then installed the valve train and found #1 intake lobe rounded out.
