Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 454 compression test
Old 04-29-2013, 06:39 PM
ss396si's Avatar
ss396si ss396si is offline
Originally Posted by 454C10 View Post
781 heads typically have rotators under the exhaust springs which are normally replaced with thick spacers when stronger springs are used. The springs have a recommended in stalled height so you can used that when you install them. The 268h is a little to big for 7.7:1cr and requires more stall and a 3.55 gear. I would get the 260h if you want to get a kit. What gear, transmission, and stall are you going to use?
My current setup is 305, 29-3200 stall, TH400 and 3.73 moser 12 bolt.
I can always change the converter when I do the bb swap.
