Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 454 compression test
Old 05-08-2013, 04:26 PM
ss396si's Avatar
ss396si ss396si is offline
Originally Posted by 454C10 View Post
You will be fine with the 268H, as the gears and stall are good. Compression is a bit low but it will work. And work with 87 octane with lots of timing. Stall is a little high as 2000 or 2400 rpm would be enough.
Use 20 degrees of timing at idle, 40 total, plus another 10 from a vacuum advance canister (adjustable, with 10 degrees of timing and plugged into a manifold source. So, it should have 30 degrees at idle (20 + 10) and 50 total (40 + 10) when you rev it up in park.
Well I'm considering buying this cam from summit: http://www.summitracing.com/parts/sum-k03052/overview/
With a edelbrock performer rpm #7164 and q jet 750cfm electric choke.
What valve springs would you
recommend?
