454 Compression Test Results - Help - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-16-2007, 09:16 PM
72NOVA454
guys
got a few things going on with the motor so I thought I'd run a quickie compression test on all 8 cylinders. Here's what I got
#1 180 psi
#3 180 psi
#5 180 psi
#7 180 psi
#2 175 psi
#4 175 psi
#6 175 psi
#8 170 psi
I think those numbers are ok. Do you agree or disagree? I noticed all the even # cylinders are a bit lower - is that ok or does it indicate a head that is not torqued down enough or a gasket that's not as tight as the other head.
thanks
lee
Old 05-16-2007, 09:51 PM
Bumpstick's Avatar
Hammer and a torch
More likely means a variation in the chamber volumes between the 2 head castings...? Looks fine to me for a street/mild strip engine...
I.Q. test willys36@aol.com Hotrodders' Lounge 57 11-25-2003 10:34 PM
compression test result question..?? mikeweyman Engine 1 09-02-2003 07:39 PM
compression test results... bad headgasket? Gino Fultano Engine 1 09-01-2003 02:58 PM
Vacuum Guage Test Results.....? (Holley 600CFM)) white66coupe Engine 2 07-15-2003 06:59 PM
454 compression general Engine 1 09-29-2002 08:13 PM
