Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 454 Crank into 402 build 550hp goal
Old 12-03-2012, 11:17 AM
BigBlock76Fbody BigBlock76Fbody is offline
So I should stick the stock sized crank in there? What bottom end should I go with to get that compression ratio? I'm open to opinions and advice. This build isn't set and stone. I'm just wanting at least 500+ hp out of this thing
