Try and use a little taller tire.. 26" tire with 411 or 456 ratio you will probably run out of gear in the 1/4. You should be able to fit a 28" tire and it will look much better.
With the Camshaft your looking at you might as well build it with some compression.. 12.1 or better. Get your 4k stall and take a little weight off the car and go racing
