454 crate motor - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-09-2011, 04:43 PM
ss396si's Avatar
454 crate motor
I was on the summit website checking out this 454 #88890530 its a 1994-1995 enginefor my 69 chevelle. Will original parts like p/s pump, alternator brackets and chrome valve covers fit?
Old 01-09-2011, 05:01 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Nada shows up for me using that #.
The '91-'95 BBC engines were the Gen 5 version- not the best foundation for a performance build. Not that it can't be done, mind you, but for a 454 build, the Mark IV or the Gen 6 ('96-up) would be my choice. Google the Gen 5 for more details on it.
Your '69 parts will fit the later engine. The only problem might come in if you were to use a reverse rotation water pump w/an early V-belt set-up, or if you used a long water pump where a short pump was needed.
GM crate Motor ? sbk12rs Engine 1 03-20-2005 09:27 PM
260 HP or 290 HP GM Crate motor Iceberg Engine 4 02-26-2005 01:26 PM
SBC Crate Motor Brian Hix Hotrodding Basics 3 07-26-2004 11:38 AM
gm crate motor 320/350 sbk12rs Engine 15 11-23-2003 08:33 PM
crate motor robbysapien Engine 23 11-01-2003 11:19 PM
