454 distributor install on a 1997 model - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-26-2012, 05:49 AM
Hey there you all.Well my problem, I'm building a 454 motor and I believe is a 1997 model. When I stab the distributor as is going down I feel when it catch the gears on the cam, but as soon as I get it all the way down, the rotor spins free like it went pass the cam gears. I'm using a HEI distributor if this help. I also aligned the oil pump shaft and it did turned the oil pump.
Help
Old 04-26-2012, 06:58 PM
vncruiser's Avatar
Gearhead
Sounds like the oil pump shaft is still not properly aligned....Turn it with a long screwdriver to the correct position and it should drop right in...
Chevy C6500 truck with 454 engine install distributor with cam sensor jwhobbs Modern Electronic Engines 21 10-24-2015 04:23 PM
distributor install bill plise Engine 2 06-26-2011 12:53 AM
Limited top speed with 1997 454 3500 dullay wayne gillis Engine 12 06-20-2011 06:33 PM
Distributor Install mightycarlo10 Engine 1 03-15-2008 10:54 AM
Distributor install 4Speeduser Electrical 4 04-08-2007 03:15 PM
