-   -   454 engine to 700R transmission (http://www.hotrodders.com/forum/454-engine-700r-transmission-226171.html)
neig52 11-16-2012 06:18 PM
I have a 1972 Chevrolet 454 engine and want to know if they make a flexplate to bolt it to a 700R transmission? I have bought one from O'Reilly's and it does not fit. The one from the 350 transmission will not work. Help.
gearheadslife 11-16-2012 06:36 PM
you'll have to know what your converter bolt pattern is..
10.750 or 11.500..
a tci converter for a 7004r has the 10.750 pattern.. TCI makes both bolt pattern..
summit/jegs/etc sell them..
tci"s part #399473 looks like it's set up for both
Crosley 11-21-2012 11:54 AM
You simply need to proper flex plate with 454 weight and the bolt pattern for the converter as was mentioned.
Some 454 plates had 6 bolt holes in smae location, some had dual pattern spacing on bolt holes for converters
Coolwolf 01-24-2013 06:20 PM
Your local transmission shop may have one in-stock or can order it. it's about 30bucks.
I bought mine from autozone after talking with there tech support..
