454 engine to 700R transmission - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-16-2012, 05:18 PM
I have a 1972 Chevrolet 454 engine and want to know if they make a flexplate to bolt it to a 700R transmission? I have bought one from O'Reilly's and it does not fit. The one from the 350 transmission will not work. Help.
Old 11-16-2012, 05:36 PM
Banned
you'll have to know what your converter bolt pattern is..
10.750 or 11.500..
a tci converter for a 7004r has the 10.750 pattern.. TCI makes both bolt pattern..
summit/jegs/etc sell them..
tci"s part #399473 looks like it's set up for both
Old 11-21-2012, 10:54 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
You simply need to proper flex plate with 454 weight and the bolt pattern for the converter as was mentioned.
Some 454 plates had 6 bolt holes in smae location, some had dual pattern spacing on bolt holes for converters
Old 01-24-2013, 05:20 PM
Your local transmission shop may have one in-stock or can order it. it's about 30bucks.
I bought mine from autozone after talking with there tech support..
700r transmission swap in 71 c10 HOT ROD TWAN Transmission - Rearend 1 02-07-2011 05:17 PM
700r 4 transmission toms1940chevy Transmission - Rearend 1 09-28-2009 09:20 AM
700r Transmission wyndian Transmission - Rearend 3 05-08-2008 01:58 PM
700r transmission problem mjhendrix Transmission - Rearend 3 09-14-2003 07:46 PM
