454 engine bore - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-31-2012, 09:50 PM
454 engine bore
how much can i safely bore a 85 chevy 454 block, and what displacement will it give me
Old 03-31-2012, 10:24 PM
matts37chev's Avatar
I don't understand?
Last journal entry: this is only a test
I am not sure
but I do know you can go 60 very easy
Old 03-31-2012, 10:30 PM
S10 Racer's Avatar
http://www.warsprints.com
With or without cooling problems?
Max would be .120 but you MUST have the block sonic tested.
Bore it .090 to make it a 473ci with a stock crank.
Bore it .090 and stuff a 4.250 stroke crank in it and make a 503ci
Personally I would not go over .060 for any reason on a daily driver and anything over .060 needs the block tested. JMHO
engine cylinder to bore or not drock3969 Engine 17 04-26-2011 01:53 PM
how far can u bore a 403 olds engine 403pontiac Engine 9 03-23-2009 07:45 AM
how to calculate engine size with different bore sizes??? inquiring_mind2 Engine 12 10-25-2008 08:05 PM
engine bore and pistons jerry1 Engine 4 11-25-2006 07:27 PM
anyone ever able to fit 3.76 bore pistons in a 3.5 bore engine? 74chevyflat Engine 15 05-21-2006 07:58 PM
