454 engine surges @ idle - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-02-2004, 06:23 PM
My engine barely idles and sometimes gets a boost surge like a plug wire is loose or something but all are tight on plugs and HEI cap they are new Taylor wires. When I rev up the motor it runs fine but when it calms down to idle it sarts running rough again.
It also has a Edelbrock #1407 750cfm carb.
Any ideas would be good!
Old 05-02-2004, 06:26 PM
poncho62's Avatar
Wiki Edits: 5
Check for vacuum leaks........carb gasket, hoses etc.
