454 Forged Crank Question
I am looking at purchasing a forged crank for my 454 project. The guy claims it is a 7463 casting but has told me that the casting number is not on the crank any longer. He claims it may have been removed during balancing. It's a standard grind and he states (I have not seen the crank yet) that it will need to be turned (I'm hoping 10/10 will clean it up) before installation. He wants $150 for it.
My question is there any way to tell if the crank is a 7463 if in fact the casting number is missing? Date code? Any other identifier? I am just a little leary of purchasing a crank that I can't confirm the identity of. When balancing a crank I fully understand that certain parts of the journal may be removed during the balancing process, but would they take the casting numbers off in order to balance? I'm guessing they might have to but I wanted to know if that was a practice. Thanks in advance for any replies. |
not to sure on this issue but depending on your application and what your doing theres an online company called CNCMotorsports.com that sells really in expensive cranks, rotating assemblies and there top quality eagle-scat. The pricing is really cheat even my machinist couldnt get kits as cheap from eagle as I could get them from this outfit. A full internal balanced 496 competition rotating assembly thats h-beam rods je pistons 4340 forged crank was only 1700. you might check there by the time you turn and prep a used crank you may be able to get real close if not right on a a new one. the 5140 forged cast are actually really good cranks if your not going to run nitrous or huffer. Hope this helps you out.
C10,
Thanks for the reply. I know how to identify a forged crank, I was just wondering if you could identify the specific casting by some other means other than the casting number. I also understand that a stock crank will get me to 6k RPM. I just figured the forged crank might be nice to have. He has dropped the price down to $150. Last edited by 31fordcoupe; 01-28-2009 at 10:06 PM. |
I would second 302 Z28 advice! I tried to purchase a "used" forged crank for my 454, turned out to have a number of cracks in it so I ended up "flushing" $150 down the drain. As indicated, have the crank checked out as a contingency of the sale. Good Luck!
| BBC Crank Question | inquiring_mind2 | Engine | 2 | 11-10-2007 08:18 AM |
| 454 crank in a 396 block | FiveFeezy | Engine | 11 | 11-30-2006 05:43 PM |
| Who knows about useing a 396 block and a 454 crank combo? | Bad Rat 414 | Engine | 17 | 10-09-2005 07:29 AM |
| 4340 Forged Crank | KA67_72 | Engine | 15 | 02-05-2004 07:43 PM |
| 454 cast crank & 3/8 rods | stepside454 | Engine | 6 | 12-19-2003 08:56 PM |
