454...."the front fell off..." - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-04-2013, 05:14 PM
Trying to put my 76 GMC truck engine back together in my '38 Chev sedan. I put a new H2O pump on, then figured out the long one wouldn't work with the alternator mount I had. As I wanted to delete the engine fan, I thought I'd just upgrade to an aluminum short H2O pump. Turned out the Alternator mount was marked for a short pump. Well, I put on the short pump, then figured out the alternator mount(one of those polished aluminum triangles) is totally unusable with it. And, to top things off,the spiffy polished pulley that came with the new pump hits the crank damper. Once I figure this crap out, I'll probably hafta reinvent the wheel in order to mount the new PS pump I'll need. Any suggestions? I'd like to avoid replacing every single thing I've managed to accumulate so far. (I'll post pix tomorrow, as I'm not at home now). Perhaps someone has pix of a completes system such as mine. And, no, I'm not gonna pony up hundreds for one of those lovely, elaborate polished multiplexes I see advertised. Only due to lack of funds, not lack of taste.
Old 10-04-2013, 07:17 PM
Newbie37's Avatar
Newbie 37
Last journal entry: Three months since started
This is my setup on my 454
Old 10-05-2013, 05:58 PM
496CHEVY3100's Avatar
Built Not Bought
Last journal entry: 53 ad3100
This might help some ,
what is the BBC mounted in
Old 10-05-2013, 07:14 PM
496, that is the alternator mount I have. I just don't see a way of bolting it to my short H2O pump. And, I need to put the PS pump low and close cuz the engine bay is teeny.
Old 10-05-2013, 09:15 PM
Built Not Bought
The p/s mount is from a motor home ,it is similar to a p/u only lower it mounts to the head ,front exaust bolt and front of the block ,I have pictures of different angles if I can get them to print..
what vehicle are you putting this in.
Old 10-05-2013, 10:13 PM
Built Not Bought
here is an original short pumo alternator bracket located in drivers side
and a long pump on passenger side
mabe you can seeee tese with a different angle
ID:	86657   Click image for larger version
Old 10-06-2013, 07:27 AM
lakeroadster's Avatar
Hot Rods are Built, not Bought
Last journal entry: Lakeroadster's '31 Model A Tudor
If you can't get your brackets to work here is an excellent source: Chevrolet Steel Mounting Brackets
The Following User Says Thank You to lakeroadster For This Useful Post:
496CHEVY3100 (10-07-2013)
Old 10-07-2013, 09:10 AM
Built Not Bought
Thanks Lakeroadster I need some brackets they have listed,i looked at the page last night after I saw this post.
Old 10-07-2013, 12:55 PM
It's going in a 1938 Chevy, so the front of the engine bay is really tight.
1999 chevy 454 ignition problems "desperate" gconcialdi Engine 4 09-14-2011 06:06 PM
"SS"-"454" Emblem Location On Fenders JohnB231 Hotrodding Basics 12 02-19-2011 07:47 PM
Wht's the best way to build a "peanut head" 454 for daily street driving jroc151 Engine 9 03-05-2008 11:33 AM
454 BBC casting "PERF PASS" pasadenahotrod Engine 5 04-26-2006 05:57 PM
Hey croz look """"IMPORTS SUCK""" 78 monte Hotrodders' Lounge 14 08-30-2002 01:13 PM
