454 Gbody engine build
I hav a 454 BBC 4 bolt main #361959,with #336781 heads,a #3883948 manifold intake, a TH400 transmission, and 8.5"posi rearend with 3. 73 gear... I'm looking for suggestions on .060 bore pistons & a cam to maximize the potential of my motor without doing any other modifications besides headers...
Using 118, use these low-dome SRP forgings..... SRP Big Block Chevy Small Dome Profile Pistons 212136 - SummitRacing.com to make a 10.1:1 static compression ratio Use a Crane "Saturday Night Special", although you'll need more gear and a 3000+ stall converter. Crane Hydraulic Flat Tappet Camshafts 134551 - SummitRacing.com Intake valve closes at 43 degrees ABDC @0.050" tappet lift and makes DCR of 8.505:1. I would shoot for 0.040" to 0.050" squish. This is just one idea, there are hundreds of ways you could make power with a BBC, including building it 8.0:1 and bolting on a small blower with this same general cam grind. |
I hav a 454 BBC 4 bolt main #361959,with #336781 heads,a #3883948 manifold intake, a TH400 transmission, and 8.5"posi rearend with 3. 73 gear... I'm looking for combination suggestions on cylinder heads, intake manifold, cam, and pistons to bore my motor over .060 & hav drivable STREET machine. (Going into a 2dr 1980 Gbody Malibu)
Hmmmm, must not have liked my answer.
Lol I reposted before I seen it, so if I was to keep the heads & intake I hav wuld I still be able to bore the motor over .060?
Hmmm! I thought I just posted a suggestion for a build on a 454 in a thread titled Edelbrock C427x manifold.
In a word, yes.
| 1954 Caddy To Build or not to Build (with a 454 big block) | ditchdoc220 | General Rodding Tech | 6 | 01-10-2013 04:32 PM |
| 454 engine build | jacks354 | Engine | 11 | 01-22-2012 09:18 AM |
| 454 2bolt 289 block or 4bolt 454 1 piece seal to build a 496 | heathj1 | Engine | 2 | 12-21-2008 10:22 AM |
| How can I build a 454 "POWER" Engine? | stevecollins | Engine | 3 | 08-07-2004 07:55 PM |
| bbc 454 maximum power engine build up | rynophilia | Engine | 6 | 07-08-2003 03:07 PM |
