-   -   454 going into my 53 3100 (http://www.hotrodders.com/forum/454-going-into-my-53-3100-a-120556.html)
chevy53 07-21-2007 12:54 PM
I just picked up a 454 out of an 88 2500 . I will be stuffing it into my 1953 chevy 3100 pickup as soon I pull the 283 w/ th350 out. Has anyone done this before? Im looking to see if there are any tricks that may come in handy. I'll be taking pics as I go along. :evil:
ronnuttsr 07-21-2007 08:11 PM
no but i will do it soon maybe
I have a 1954 with a 283 and my steering box is very close. I am going to pull my 283 out sunday. i am going to paint my fire wall and redo my motor supports they are solid no rubber. I am going to put a new truck independent front suspension, that i found on this web site.( the plans not the front end) After that if i find a good 454 I will put that in or put the 283 back in till I fine one.I will reply if i do it first. you tell me if you do it first.
ron
katy Tx
Centerline 07-21-2007 08:48 PM
Well one things for sure, you know it will fit. I put a hemi in my '53 3100. :mwink:
chevy53 07-21-2007 09:27 PM
What kind of radiator is in the the truck to cool the hemi? I have the radiator for the 454 w/trany cooler I will be attempting to fab into place. There is plenty of room for the motor its all the other stuff Im thinkig about like steering, radiator, how far back to move motor, and how to route the headers/exhust. Id like to route the exhaust it right out of the side so I can dump it into those annoying imports i plan on blowing the doors off of. :D
Centerline 07-21-2007 11:06 PM
I have a PRC aluminum radiator made specifically for the AD trucks. As you can see the truck has A/C and a separate trans cooler.
http://www.hotrodsandhemis.com/running/dway2.JPG
I'm also using a home made shroud and mechanical fan. Haven't made the decision yet but I might go to an electrical fan next year.
http://www.hotrodsandhemis.com/running/gromet.JPG
Mine has a Mustang II IFS which gives me more room for steering since it uses a rack instead of a big box.
As you can see the hemi completely fills the engine bay so I needed all the space I could get for steering.
http://hotrodders.com/gallery/data/5.../1280trees.JPG
Running headers out the sides behind the front wheels (gasser style) will require a lot of fabrication but can be done. I used stock high performance manifolds simply because I had them. Could have used block huggers but it's not a race truck so I saw no need to go that route.
CptKaos 07-22-2007 07:49 AM
It will fit, but you will need a good radiator, push the firewall on the right side back a bit and move the steering column over about an inch, we also relieved the frame some to clear the steering shaft (headers are Sandersons, radiator is from Griffin)
Larry
http://i81.photobucket.com/albums/j2...s/IMG_3523.jpg
http://i81.photobucket.com/albums/j2...s/IMG_3518.jpg
1952_Chevy_Panel 07-22-2007 09:34 AM
My dad has a 454/TH400 in his 54 panel. We clipped it using a 79 camaro clip. Definitely have to modify your inner fenders to clear everything.
66GMC 07-22-2007 10:40 AM
CptKaos.
Very nice!
I couldn't help but notice that you have plugged your by-pass hose connection on your intake ...
Why?
CptKaos 07-22-2007 09:22 PM
don't need it
Larry
Rambo_The_Dog 07-22-2007 09:34 PM
Larry
Nice looking setup!
Although not the same animal - I bought some Sanderson Cast Headers for my 454 install in my 49 Hudson - these really help when clearances are tight and actually fit tighter against the block.
http://www.49c8.com/images/Work/Stee...ockUp_1med.jpg
Deano54 01-18-2013 09:24 PM
I am installing a 454 in my 54 too, was wondering if you had to do anything to your firewall to make room for the distributor? I have a recessed firewall to install but I mocked it up and it looked like I needed to move it back a few inches still, any thoughts?
