454 in a half ton - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-23-2008, 03:43 PM
454 in a half ton
I have just pulled the engine out of my 84 half ton GMC 4x4. It has recently had the body restored. I was wondering about the engine. it is a 454 but that is as much info as I have about it. above the timing cover is stamped T1028FBK, on the back drivers side is cast 14015445 with a P under it, once I pulled the flywheel off is says Hi Perf Pass. what year is it and what did it come out of. The top end has roller rockers and manley valves so someone has shown it some love.
Old 12-23-2008, 03:53 PM
techinspector1's Avatar
Wiki Edits: 326
Pull a valve cover and post the casting number off the head.
Old 12-23-2008, 04:23 PM
GM3T
Pass
346236
Old 12-23-2008, 04:54 PM
Wiki Edits: 326
'73-'87 454 oval port, 120cc open chamber, 225cc peanut oval intake ports, 116cc exhaust ports, 2.06"/1.72" valves.
0.100" 54/35
0.200" 123/84
0.300 184/117
0.400 222/141
0.500 226/156
0.600 226/160
They'll be fine for a "go to the grocery" torque motor, but I wouldn't use them as a base for any kind of performance use.
1979 silverado half ton with 350 small block HotSpringsGal Hotrodding Basics 3 10-05-2006 12:03 PM
Squeezing a little more power out of my 454 RObs71Nova Engine 8 05-21-2005 04:38 PM
From A 1 Ton to a 1/2 ton Flanders Hotrodders' Lounge 5 07-27-2004 12:17 AM
88 chevy 2 ton cab to 80 3/4 ton frame stoneyone2001 Body - Exterior 1 11-11-2003 09:43 AM
75 dodge half ton posi rear end 81elcamino Transmission - Rearend 0 10-26-2003 03:33 PM
