454 head issue - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-27-2013, 12:29 PM
454 head issue
Hi, I have 454 that is heating up at idle but runs cool at speed. Preliminary checks show no water in the oil but it is surging water in the radiator. This shows compression in the water system so it is either a cracked head or head gasket. Does anyone know of a quick way to check either?
Thanks in advance..
Old 06-27-2013, 12:52 PM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
How long has it done this (is this a new build)? Not trying to be a wise***, but are you sure you have the air purged out of the system? Are you seeing air bubbles?
Old 06-27-2013, 01:10 PM
Head issue
Its an older build, no bubbles but if i take rad cap off i see surging with cam
Old 06-27-2013, 07:10 PM
BOBCRMAN@aol.com's Avatar
Probably bad head gasket from improper install or incorrect gasket.. BBC heads are pretty tough to crack..
Old 06-28-2013, 05:41 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Thanks in advance..
You can use a compression tester (engine warmed up) to isolate the problem to one bank. Then pull that head and inspect for a bad gasket or cracked castings (block or head, neither is as likely as a bad HG as said already).
Old 06-28-2013, 07:38 AM
454 head issue
I agree with the bad head gasket. As many different head gaskets for sale today for a 454 engine it wouldn't be hard to purchase the wrong gasket. When installing new head gasket make sure all the water jacket holes align.
Old 06-28-2013, 11:00 AM
Thanks to all. I'm going to pull the heads off today
454 backfiring issue jodylawrence66 Engine 3 10-11-2011 09:57 AM
454 rebuild issue wmfirefighter09 Hotrodding Basics 8 03-21-2011 08:41 PM
'81 454 vacuum hose issue '81 RV guy Engine 1 06-08-2010 08:57 PM
454 timing issue Fastest65 Engine 3 07-27-2009 02:44 PM
Head gasket issue? v8hed Engine 12 12-30-2008 07:00 AM
