454 horsepower rating 1990rv - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-08-2012, 10:26 PM
hi, my name is steve . been a gearhead for about 35 yrs'i just wanted to try to find out how much horsepower is in a 454 1990 r.v. Would appreciate some info thanks
Old 01-09-2012, 11:33 AM
327NUT's Avatar
It's a whopping 230 hp and 385 lbs.ft. torque, the SS pick up had 255 hp...supposedly. Those 80's 454's suffered from very low compression, about 7.5:1 and crappy heads.
Old 01-09-2012, 03:00 PM
Last journal entry: update
230 HP at 3600 RPM, 385 HP at 1600 RPM. 7.9:1 compression. The heads weren't any real problem. The '91-'93 454SS had 255 HP at 4000 RPM, and 405 TQ at 2400 RPM because of the exhaust system.
These are the peanut-port heads, but with no porting, and the right supporting mods, a 9.5:1 ( requires swapping in domed pistons ) 454 with a Comp XE268H10 cam can pull 5500, with 446 HP at 4900. Not bad.
Some will suggest the large-oval-port heads, but those will actually cost you enough torque to feel the difference, especially below 3000 RPM.
Horsepower rating for sbc 4 bolt main block? beemdubya Engine 15 10-29-2009 06:52 AM
real horsepower rating for 400 pontiac zeke51 Engine 8 04-02-2009 03:59 PM
rating retired 56 Transmission - Rearend 6 02-16-2007 06:18 AM
Horsepower Rating 350 Lepracaun Introduce Yourself 1 06-29-2004 07:10 PM
Confused on horsepower rating olds37dude Engine 18 12-01-2003 01:45 AM
