454 install in a 55 chevy 210 post - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-10-2008, 02:19 PM
chevy bb 572's Avatar
CHEVY BIG BLOCK 572
Last journal entry: sum rides i got
looking for info,tips,suggestions,etc.im putting 454 in a 55 so far ive pushed the firewall back for valve cover clearence. ive ordered front mounts.they say you can do away w the trans mounts that are below the firewall.would i have to make a trans crossmember?can i just slide the trans foward?cam i use the edelbrock street fule pump or do i need to go w eletric?all the info would be great for my install thanx guyz
Old 11-10-2008, 03:19 PM
I put a 427 BBC in a 55 Chevrolet many years ago. I suggest you mount the engine with side mounts ... just like Chevrolet mounted their 427/454 engines. Then install a cross member under the transmission ... like Chevrolet did. There are kits to do this ... now
I had to fabricate all that stuff back then.
Old 11-10-2008, 05:52 PM
yea them kits are best , you get
oil pan
headers
mounts
metal for cut outs of valve covers and distributor cut out if you use the big
74 THROUGH 86 HEI .
Old 11-10-2008, 06:11 PM
302 Z28's Avatar
I helped a buddy drop a 427 in a 56 210 about 20+ years ago. We used fabricated side mounts and a fabricated cross member, it worked great. Of course today you can buy all that stuff pre-made.
I agree wit Deuce, side mounts and trans cross member is the ONLY way to go.
Vince
Old 11-10-2008, 06:27 PM
NEW INTERIORS's Avatar
Set no limit's on yourself
What ever you do,Don't run a big block with front engine mounts.It will not hold up.I had a 427 in my 57 Chevy,But I had a camaro front clip.Worked out great with the side mounts.Here's a pic of the trans cross member I made.
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
Attention: Willing to trade a *********for 55 buick or 48-54 chevy... DeathByGreaser Hotrodders' Lounge 5 10-23-2009 08:49 PM
rubber brake line's for a 55 chevy tiresmoke55 Suspension - Brakes - Steering 6 01-16-2006 08:26 PM
55 chevy sedan coil springs & A-Frames Q Stew Suspension - Brakes - Steering 11 12-18-2003 06:48 PM
55 chevy engine swap timrocket72 Engine 0 11-04-2003 09:33 PM
