454 intake manifold gaskets
Use the part # from this summit racing website and see if your local auto parts store can get you the gaskets. If not go to a speed shop in your area. http://www.summitracing.com/parts/FEL-MS902402/
Edelbrock verses Wieand
This doesn't have anything to do with your gasket question, but the title of your thread peaked my interest.
If your running a edelbrock two plane and your motor is at all hopped up seriously think about discarding the intake for a wieand. The edel in my opinion is junk, the 454 needs to breath, even port matched the edelbrock is a downer. even just looking at the runners you can see the weiand is a better intake. Ive run both on my 461 and the weiand pulled way harder all over especially on top. IMHO Pete |
I typically use the exhaust crossover restrictors since I live in a warm climate. It still flows, just not as much.
I have been putting on intakes for over 30 years and I have never seen water port restrictors. Even on a mild build, I like the RPM intake over the performer intake (if you have the hood clearance). Not the Air-gap RPM, but use the regular RPM. Make sure to get the intake that matches your carb style (spread bore or square bore). Use a thick bead of rtv on the front and back ends of the intake and throw those end gaskets away. |
Gasket dope
I think the 4 restrictors that your looking at are the peices you put together to make the exhaust gas restrictors, they come in a little manila envelope in the kit, the peices sandwich together and theres these little tabs that come out of the hole you bend over to keep it together.
I think the resrictors come into play more when you have stock exhaust and the engine spends alot of time idleing in a hot inviroment. If your running headers then the exhsaut gas deverter valve is long gone and there anint much gas traveling across the intake and you could probly leave them out all together. |
| Tags |
| 454, bbc, gasket, head, intake manifold |
| LS6 454 intake manifold | 1967chevelle454 | Engine | 2 | 02-21-2010 03:54 AM |
| 454 Intake Manifold Gasket ?'s | Ignitrous | Engine | 3 | 12-06-2009 12:39 PM |
| intake manifold question | cve63 | Engine | 4 | 09-05-2005 01:19 PM |
| intake manifold question | douhavit | Engine | 1 | 05-05-2004 07:43 AM |
| Intake Manifold Question | CorvetteSteve | Engine | 2 | 05-29-2003 05:05 AM |
