454 into 1956 stepside
Anyone know if you can transplant a chevy big block into a straight axle 56 chevy stepside?It has the stock steering box which seemed to hit the exhaust manifold. Will block hugger headers help. Will the stock straight axle hold up to the added weight?
I installed a real LS-6 454 - 450 Horsepower 70 Chevelle engine in my 55 Chevy Camaro pickup years ago. I moved the engine over about a inch or maybe a inch and 1/2 ... I used a 69 Nova Big Block 4 core radiator ... a 67 Chevelle 396 short water pump and pulleys. I used a Turbo 400 automatic transmission.
My 454 was NOT in the same exact location a factory SBC would be ... I moved it forward just a little bit ... maybe a inch ... I used a crossmember type of engine mounting system ... like the one shown above. The steering and the straight axle held up great ... but the big engine really made you want better brakes
DEUCE, I didn't know chevy made camaro pickups. LOL "CAMEO" MERRY CHRISTMAS.
Thanks for the info, I thought about moving it over, but was'nt sure if there would be a problem with the driveshaft being at a slight side angle. I already have the engine and am planning on getting either a t400 or 700r4 to bolt up to it. I'm glad somebody knew if this was possible, knowbody I've talked to semmed to know. Thanx, Mike.
Use the TH400, a big block will fry a 700R4.Also moving the engine over does not hurt. A chevy astro van comes from the factory with the engine offset to the pass. side for foot room by accelerator.
It was a Cameo ... I had 5 of them at one time ... Most were " parts trucks " Two were drivers ... one with the 454-450 and one with a 350/370 LT1 from a 70 Corvette I should have been saving all that good stuff back then instead of using it and tearing stuff up ... Oh Well ... thats what makes that stuff RARE now
Yes, you can. You'll have to notch the front frame crossmember to make room for the harmonic. You will want the engine as far back as the distributor will allow so you can get the radiator in (It will still take some engineering). The stock box will fit with the correct headers as will a saginaw conversion. You won't have to move it over. I'm working on my second one now. Staright axle isn't a problem but a conversion would be better. Larry
Great picture, what type of headers are you using?
I wish I could remember for sure. I know we used Sandersons on one of the two 57s but I'm not sure which. I looked in the file today but the slip isn't in there. Must have been a cc purchase. I'd check with Sanderson first and tell them what you are doing. I'll keep an eye out for the invoice.
Larry |
Well I've got a '55 I converted over to a 4x4 and a big block...I used headers from a 70's/80's fullsize Blazer....they clear ENERYTHING and fit good. I did have to modify the firewall for valve cover clearance, which can be seen in my photo album. The end result came out pretty good....the firewall doesn't look hacked, it almost looks factory.
| Recent General Rodding Tech posts with photos |
| 70's 454 or 80's 454???????? | inquiring_mind2 | Engine | 2 | 11-26-2007 08:25 AM |
| 454 BBC heads by FoMoCo?? | WakBordr7387 | Engine | 9 | 06-13-2006 10:30 PM |
| Engine Swap 1956 with '97 454 many ????'s | Sick56 | Engine | 3 | 10-22-2005 08:14 PM |
| Squeezing a little more power out of my 454 | RObs71Nova | Engine | 8 | 05-21-2005 03:38 PM |
| 454 or 427 for 70 Chevelle? | f100beatertruck | Engine | 3 | 11-25-2003 05:29 PM |
