454 In A Jet Boat Have Sparkplug Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-03-2006, 07:57 PM
bigbad66chevelle's Avatar
Hey guys i have a 77 jet boat with a 454 in it. Pretty mild cam 10:1 compression just a nice healthy big block.So my question is i'm getting her ready for spring and was wondering if you could tell me what spark plug i need to get. Like an actual part number. I called kragen and since i don't have a specific application they are no help to me and i could just put the same plugs that are in there now but there just auto-lite and i wanted to put some good NGK or something else a little more high tolerance......thanks guys....any other suggestions would be appreciated...
Old 03-03-2006, 08:00 PM
97Z28's Avatar
NTI Grad.
http://nology.com/crossref.html
use this cross reference chart to find the spark plug you need....
Old 03-04-2006, 06:50 AM
Guy Hiltz's Avatar
Spark Plugs
I use AC Delco R43-T plugs in my Big Block LS-6 ,they are a bit of a cold plug but seem to work quite well.Also the Big Block is known to be hard on plugs so I just change them every year.Hope this helps.
Old 03-04-2006, 07:50 AM
Last journal entry: 500" roller motor for the coupe
Ditto to what Guy said.
I have a 78 Brendella Jet with a bigblock in it. I run the 43s as well. Never an ounce of concern from them
simple Q jet question layinitdown Engine 2 05-07-2003 03:57 AM
454 swap question nitro junkie Engine 2 01-12-2003 07:32 AM
Q Jet question dion Engine 2 11-27-2002 07:28 AM
Chevy 454 to 489 Question Project 64 Engine 3 11-05-2002 03:58 PM
454 rotating assembly question BlackRat Engine 2 11-05-2002 09:38 AM
