454 main cap question - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-02-2006, 11:08 PM
1969NovaSS's Avatar
turbo lag......yeeeeehaaaaaaw
I finally pulled my 454 apart and found trash all over the place. all rods were discolored, 1 rod bearing was MISSING, one wore paper thin( i think thats were the trash came from), 3 main bearings started to spin but there are no grooves or marks on the crank or mains( thank god). but my question is this. the main caps are not put in order. it goes rear cap, 50, 51,53,52. Is that okay? It seems like it should go in order, all the other engines i built did. I know someone did work on this cuz it had a crane cam and the rods are not in the right holes so i dont know if the previous owner messed it up. any help is greatly appreciated.
Old 03-03-2006, 05:53 AM
Bumpstick's Avatar
Hammer and a torch
Man that sounds like an oil pump went south in a hurry...?
Old 03-03-2006, 06:38 AM
engineczar's Avatar
You really can't trust the cast in numbers for their positions. The #5 cap is obvious the rest could be sorted but you would need a dial bore gage to get them matched up.
Old 03-03-2006, 09:18 AM
1969NovaSS's Avatar
BB main cap question
So im better off telling the machine shop the situation when i take it to get machined. I dont want them to align hone it with the wrong caps on it .
Old 03-03-2006, 09:39 AM
engineczar's Avatar
Yes mention to them that the caps aren't in order.
Did you look real close for any stamped numbers on them? Sometimes they're there but really faint.
Old 03-03-2006, 03:24 PM
Seems to me that most are numbered from the factory, but if you are getting it aligned it shouldn't matter right?
454 bbc cost question 406 ss monte Engine 9 01-16-2005 07:02 PM
BBC 454 Heads / Gaskets question rakundig Engine 10 02-05-2004 07:36 AM
broken main cap hmmm Engine 6 05-19-2003 08:42 AM
broken main cap Jared Engine 5 04-23-2003 09:47 PM
Main cap installment KentuckyCamaro Hotrodders' Lounge 2 11-05-2002 07:18 AM
