454 main caps dont fit - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-24-2010, 03:43 PM
So I was doing a "pre assembly" and noticed the main caps are too wide to fit in thier registure... Just a hair! Is that normal? I thought it was suppose to slide right in to its slot... This one ALMOST does but not quite..
Old 04-24-2010, 04:12 PM
There supposed to have slight interference fit, thats what keeps them from walking and moving around.
Old 04-24-2010, 06:07 PM
BOBCRMAN@aol.com's Avatar
Line em up, put bolts finger tight in em, and lightly swat em with a brass hammer. They will fit perfectly.
Old 04-24-2010, 07:20 PM
ericnova72's Avatar
More for Less Racer
Yep, they're supposed to be tight, if any of them just fell into place without tapping them down or pulling them down with the bolts then they are not tight enough and could lead to cap walk problems in use.
Old 04-24-2010, 08:34 PM
thanks! I was worried there for a sec makes perfect sense though.
Main Caps Bolts wally Engine 9 04-24-2010 06:59 PM
main bearing end caps 12 bolt elcaminodragster Transmission - Rearend 7 07-17-2009 01:00 AM
Mixing bolts and studs on main caps Harley Monster Engine 10 01-02-2008 08:08 AM
454 main cap question 1969NovaSS Engine 5 03-03-2006 03:24 PM
whats too much bore and stroke for 454 2 bolt main mean_1 Engine 1 07-23-2004 01:50 PM
